Slow download speed
Hello
The internet was installed yesterday. My internet is not up to speed.
I ordered
Download-1gb Upload-50mb
There is now
Download-10mb Upload-50mb
  • Slamb změnil název na Slow download speed
you first restart the modem by disconnecting from the power supply for at least 30 seconds, so measure the speed again, if it doesn't improve, then contact Vodafone technical support
Yes, I tried almost 10 times
I don't know how to contact a technician. 800770077 is busy.
You can contact Vodafone via this link
https://tam.je/forum
or try phone number 800777731
Waiting for 16 min. music play. Its not funny😪
Modem OK
PC OK
Cable OK
35 minut.Not her english language operator
Zdravim a pridavam se - stava se me posledni cca 4 dny to samy - down 2 - 6 Mbit - Up ani tech 50....jen kolem 12 - 20. Neni to celej den, nepravidelne, modem odpojen, reset, PC reset,....nic. Nikdy jsem nemel zadne vypadky. Ping v pohode - 8 - 16 ms bez packetloss....mel sem podezreni na DNS....ale v Win10 jsem si nastavil servery google a problem je tam stejny....dokonce jsem nameril 2.6 😞 Praha-Nusle. - jinak kabely Belden zasuvka nova, vse OK
  • 1000 Mb/s
  • ∞ GB 10 Mb/s
  • VF Station, CA modul
  • Praha-Nusle
@Mandukhai
You contact Vodafone via this link
@Trabi pravděpodobně tam máš nějaké rušení signálu, kontaktuj Vodafone,
Můžeš kouknout ještě do modemu do záložky download jak to tam vypadá s kvalitou a úrovněmi signálu, nejčastěji bývá rušen OFDM kanál.
Mam to takto:
  • 1000 Mb/s
  • ∞ GB 10 Mb/s
  • Praha-Nusle
Morning no internet.
Now...
One question
My Vodafone - login number and Pass?
Zákazníckume účet číslo xxxx?
Pro plátce xxxxx je xxxx?
Day 4.
No one is helping. I went to the branch. It didn't help me. Work was slow due to poor internet connection. Now I'm starting to regret my choice
